GM HEATER HOSE FITTINGS
okiefireman
How do you get them a part ? I have one broken and need to change it but how do I get the broken one off? It's on my 01 GMC YUKON xl 2500 has rear heat and it's the one the plug into the yellow tee from the engine (8.1 ). Thanks
txab
Don't get stuck on stupid!
Auto parts store will have one. It should be this
okiefireman
And what do I do with it? Not to sound dumb but I don't see how that works
txab
Can you snap a pic of the bad fitting?
+1
The one I posted above slips around the HC pipe, closes, then you pull it into the fitting forcing the locking tabs to release. Used on this type of fitting
getimage.php
Depends on how bad the connector is broken. The tool Darral posted is correct. I'll tell you now, even with it, the hose connect will be a PITA to remove. Its why I asked how stated how bad it was. It may be easier to get a dremmel(if you have one) and use a cut off wheel and carefully cut it off.
If you use the disconnect tool, make sure the part that fits in between the connector and the barb is long enough. Sometimes I find they can be too short. I have two styles, just in case. See the difference below.
Just take your time and use some WD40 to help get it ti break free.
