Givin' Dodge a li'l glory..
slims
gonzales LA.
if you still have it in about 4 weeks i might take the old bumper off your hands. i might take the tires too, the change in size really woke up the top end.
slims
gonzales LA.
the tires you had on there are 4 1/2 inches shorter than wat i had
Chad7n7
Louisiana
ok, that's cool....those tires are a little wider, and a little bigger, but not by much, I just had to go with a narrower tire, and a I just went a little lower profile to make sure I was gonna be able to lay it out. Now with the 22s I have to do a little modifying to the front to get it all the way down....it's only like an inch, but that's an inch too high!! :pimp:
slims
gonzales LA.
im wanting to see wat this did to my 1/4
Chad7n7
Louisiana
needa give that thing a better stance.....give her about a 4/6 or a 5/7 drop....handling difference will be like night and day...won't be as "spongy", also put you at a little more aerodynamic position, vs. being like a big bus comin down the track!! :lol:
slims
gonzales LA.
I still need to pull a trailer and put a 4 wheeler in the back. Could i still use it as a truck with a 5/7 drop?
Chad7n7
Louisiana
definately bro....I can still use mine as a truck, and it lays on the ground!!! Only thing restricts me from putting my 4 wheeler in the back is not having my notch covered right now, that's why I want to get that done, I need to have my truck as a truck!!
In your case, you're not removing your hitch or bumper, so you can still pull a trailer with no problems, mine I have to put a hidden hitch behind the license plate box, which is still all in progress.....also, you're not cutting the bed for a notch with a 5/7 either....so the bed will remain as it is now.
slims
gonzales LA.
ok. a guy at work said he'll drop it for me whenever i want.
Chad7n7
Louisiana
that's cool....just be sure to do it right, and invest in the right parts to do it. If not, you'll face alignment issues, and lose ride quality. I just went through pics all I have is a front shot of mine at 5/7...but it does show the cover what it looked like painted....
