First Dana 35 gives problem and now Dana 44, advice
OG-Unleashed
WHAT A LIFE RIGHT.....
SoCal
so a few weeks ago i went out on a rocky trail with one of my buddies and somehow i broke my spider gear in dana 35
then i also realized it also wouldnt fall into 4x4, and took the ford apart and it broke again
i ended up getting a new one and need to replace that but for my rear i ended up swapping it out with a dana 44 that i was planning on building then installing it but since this happened i had to swap it out
the guy who i bought the dana 44 from had 3 different ones with different gear ratios, the one i got was a LSD with 3.07 gear ratio to match the front for now
the problem i am having now is every time i throw it into reverse the differ makes a clicking noise, (the noise the dana 35 made when the spider gear broke)....i have a 1991 Xj 2 door with a 5 speed tranny
i want to change the gears to 4.56 with a locker in the back and LSD in the front but inorder to do that i need to save up
my question for now is, why is it making that kind of noise? is it because of the 3.07 gear ratio with the 33x12.50 tires?
Is it a locker? Have you had the diff cover off and looked around?
OG-Unleashed
SoCal
the dana 44 i put in is a LSD and yeah i took it apart and cleaned it up before i put it in and put in LSD gear old
not the best pics but its what i had took lol
I bet you are hearing the LSD clicking (ratcheting).
OG-Unleashed
SoCal
I bet you are hearing the LSD clicking.
i dont think so just because when its just park there and i move the jeep back and forth slowly, it makes a clicking sound and you can hear it
same noise seemed to make when the spider gear broke on the dana 35 and when i move the dana 44 tire and when it makes the sound, the tire stutters at the same time it clicks
get me?
It's possible that the LSD is fucked up. Hard to make that call here though man.
OG-Unleashed
SoCal
hmmm dam, i dont wanna take it off road till i am able to figure it out before i get stuck out there in the middle of no where lol
