I just checked a diagram for a 99 3500 truck, and it does say its a purple wire (-) .
I'm betting the black goes to ground and the purple to one side of the switch to disable the dome light that's located at the headlight switch. If I tap into the purple at the headlight switch that should give me a negative trigger for the alarm if either door is opened, even if the switch is set to disable the dome light.
I know you'll get it worked out. If you can't, nobody can!Got the fwonker installed today but I evidently screwed up somewhere. As soon as you turn the ignition off the interior lights come on, then, when you get out, the system won't arm from the remote (it self-arms after 60 seconds though), it leaves the interior lights on, and will not disarm from the remote.
I went over the wiring three times and can't figure out where I screwed up so I just pulled the fuse for it for tonight and I'll work on it again tomorrow.
What kind of alarm is this?
