distributor issue?
63chevystepside
High speed low drag.
us
Working on Nova again. Having a small pop out exhaust around 3000rpms. And iv eliminted everything but this...Was wondering if i have a stock rotor but brass dist. cap would that make a issue?
I do have a brass rotor iv tried but it catches on the curve kit and makes it run the timing up like im wot while its just at idle.
2nd question is if it fixes the problem by putting on the brass rotor but it catchs the curve kit which leaves it at the wot timing while just idling. I could'nt do that could i? Thanks guys for your input.
Re: dist,/rotor issue?
Have you thought about switching to a GM HEI distributor and doing away with the old points type?
63chevystepside
us
It is a Hei dist. it has a curve kit, stock rotor, brass dist. cap, super coil. Issue is its a stock rotor and brass dist. set up.
gmctrucks
TEXAS H-town.
Check the plastic bushing or maybe springs are the same color meaning you didn't mix them up?
