Best Way To Change Fuel Pump 2000 Silverado
That will work. :thumbs: I just took the entire bed off. Just needed one extra person to help lift it off and on.
Now that I know how easy my fuel pump went I will be removing the bed this summer and doing some cleaning up under there and under coating ;-)
If you have some help to lift it off, a forklift, overhead, or even a comealong...removing the bed is the way to go. Yeah, you can really clean up a lot under there.
This is when we did my son's '02:
Dartboy
Connecticut
If you're rustproofing- try to do some at the brake and fuel lines where they pass by the front driver's side wheel well. Chevy didn't extend the fender liner far enough, so there's a gap for road grime to shoot right into those lines. Just spent >$2K to have them replaced on a truck at work.
Farmer2
I have a two ton engine puller that should work well for this. I could lift it just like in the fork lift picture.
Thanks for the ideas!
Mine went out this summer. Since I can't remove the bed on a Suburban, I had no choice but to drop the 30 gallon tank which happened to still be about half full. I ended up tilting it down so I could drain as much of the gas as possible into a bucket. I then had my 16 year old son help me lower the tank completely and slide it out from under the truck. It actually wasn't too bad, other than the stubborn quick connect fittings on the fuel lines not easily releasing. But since I used a AC Delco pump, hopefully it will last another 15 years just like the original one did. :thumbs:
If the pump ever goes out ony wife's car, it should be really easy to change. Most Nissan cars have an access hatch under the back seat to easily access the fuel pump. Ever Altima we have owned has it, but I've never had to replace a fuel pump on one.
Should have put an access hatch, lol
