Bad U-joint symptoms?
Kennyray
Ossian, IN
The level is good but its brown. Looks like motor oil in there. Don't know why it would be so brown.
Brake fluid attracts moisture, the brown is from corrosion in the system. I would bleed the system which should also flush it out.
Best place to bleed it from?
Good question. The slave cylinder should have a bleeder on it. You could crack it and do a gravity bleed or have some one pump the clutch like you would when bleeding brakes.
slims
gonzales LA.
Welp. The clutch goes all the way to the floor board with ease. Won't even start now. My brother works at carmax and he's gonna get the mechanics to take a look at it.
slims
gonzales LA.
Decided to take it to my brothers work and it lost the ability to go in first and reverse on the way. Shortly after I got there the clutch pedal was useless
Kennyray
Ossian, IN
I think it has to to with the clutch safety switch and I know either your clutch or the master or slave is fucked.
slims
gonzales LA.
I have the funds to let carmax handle all of it so I might skip out on the fun this time :lol: gonna let someone else deal with it for a change
slims
gonzales LA.
Every salesman there has my phone number now though :lol:
slims
gonzales LA.
One look at my truck and they were running out the door to show me around the lot :lol:
