Adjustable fuel pressure regulator
Texas1911
Son of the CLOWN
Austin, TX
Say what you want but several people with SVO's and turbocoupes run the same setup and are getting 300hp
They are raising the fuel pressure to accommodate the lack of flow in the injector.
Fortunately for you, running a bigger turbocharger means you'll run more efficiently and won't need as much fuel to make the same power as the OEM one.
You should be making about 300whp at around 14 - 18 lbs. of boost depending on the camshaft and turbo specs.
