A/F gauge
La Bestia
resident tool whore
Larsen, WI
I was just going to ask if you wanted another analog to match the look or if you were looking at digital. If you're not dead set on the analog gauge I recommend the aeroforce interceptor scan gauge. It can monitor pretty much any parameter that your computer reads including the trans temp on most vehicles. If you have a dual gauge pod I would honestly get the double interceptor setup so you can actively monitor 4 parameters at once with the 2 gauges.
Only thing I don't really like about the interceptors or most digital gauges for that matter is you can't really dim them. Interceptor has a night mode where it inverts colors so it's not as bright but it's still kind of distracting if it's sitting right in front of your other gauges you're trying to see.
Alljackedup408
Shut Up Stupid
Titusville FL
thanks!
Yeah Im just looking to do this in the near future... as Id like to keep an eye on that trans temp! It will fall into place like usual... when the time comes haha.
BLOWN454
Long live the big block
I would say A/F because they are fun to watch when you're bored, like when I'm sitting in the Carls Jr drive through, the light ring around the outer edge jumping around and the digital numbers moving around. Gets a little bright and attention grabbing at night but you get used to it. Although I guess if you aren't forced induction or anything serious it wouldn't be of much value? I like mine though. The Aeroforce or PLX OBDII gauge might be better bang for the buck though because of how many parameters they can display compared to just one AFR gauge.
mrolgren
The Dude Abides!
Queens, NY
If it is a little too bright you may want to try this trick i found online a while back.
http://www.truckmodcentral.com/forums/showthread.php?t=15290
Sunset_Z28
Chinga Tu Madre!
Newcastle, OK
I think it will look wimpy. As a matter of fact i think everything you do from now on is gonna look wimpy. :jester:
