Havn't gotton to work on it much. Let the frame soak with "mean green" for a while, And then pressure washed it. Found a few issues, And then fixed the issues.
Oh yeah, You wish you had that epicass bench grinder set up
As you can tell, Ray Charles did the first patch job... I put the bottom plate in.
Pulled the rear lift blocks and shocks. (Sold the rear shocks and two front shocks for 100 bucks
... I had already ordered new shocks.)
Also pulling the rear end, To swap in the 12bolt. Was going to wait till i put the gears in the ales before swaping them over, but just going to go ahead and swap it, while i'm in the while wheeling and primer mood.
More wire wheeling and primer.
Also removed all the extra tabs and mounts on the frame i won't be using. Got some front shock mounts to still remove. And one rear shock mount to remove.
