400 kick down
63chevystepside
High speed low drag.
us
Have been running my 400 without kick down an want to hook it up-other than adjusting it to wot-can i just run a toggle switch and turn it on and off? Can i just leave it on all the time? thanks.
Isn't it a cable?
I think most 400's were electric, run 12volts to a switch and then you can control it when you want. TH350's had mostly cable operated kickdowns. IIRC
Sent from my ADR6400L using Tapatalk 2
63chevystepside
us
Yea 400 are electric-at wot-you need the kick down hooked up it builds up the pressure for the clutchs and it overrides the vacum canister...It does more than dropping down to lower gears.I ran a toggle switch so i can hit it at a dead stop an then jump on it getting down the road...thanks guys.
66nova
Fort Worth, TX
Full manual valve body FTMFW!
Sent from Ft. Worth TX
