4 inch lift. Tires
SUPERxDUTYxV10
atleast its not a 5.4 lol
So was talking with a buddy today today and figured out that I have a 4 inch lift instead of just a leveling kit so if I wanted I could fit 37's. So if I wanted I could get them military tires I want and not worry about clearance.
What size tires do u have on your 4 inch lift???
Are those military tires safe for on road use?
buRRp
Supporting Member
Staff member
Supporting Member
Get some General Grappers.
SUPERxDUTYxV10
As far as I know YES I know some dude who had 325/85's and used to tow a horse trailer and I know another dude a river rat guy with a truck with 02 super duty with a 24 inch lift running 49's from this guy 100dollarman.com
canuckz71
Nothing runs like a Deere.
Alberta
Cooper STT's. Made by toyo and same but reversed tread pattern of toyos open country m/t.
Also I'm not sure if 37's would fit. If they are stock wheels you could fit bigger then if you had a wheel with a positive offset. Since your tires are 34's now I'd think it would plausible but you might have rub a bit. I'm sure it will look pretty stuffed.
buckshot85
Hampton S.C.
Most guys around here with 6" lift run 37's i'm not sure if 4" will be enough. I'd look into some 35's.
Ricky Bobby FX4
"shake 'en bake"
Everett, PA
You should be able to fit 37's with no problems with a 4 inch lift. Some leveling kits say you can fit 37's on super dutys.
