2006 Silverado Front Suspension (A Little Help/Guidance)
M.Cueva
jrrod2004
Austin, Texas
Hey guys, I have a problem that is becoming ever worse on Sally (truck).
the front end is losing contact with the roads when I go over pot holes, bumps or uneven roads. Shocks were replaced all around about a year ago with new ones (same OEM parts).
Info on Sally:
'06 Silverado 2WD with coils/shocks in front. OEM 17" aluminum rims/tires.
Any suggestions on how to eliminate this problem?
What kind of air pressure are you running?
35 should not cause any problems. I say the issue is OEM shocks. Some KYBs or Bilsteins would likely solve the issue. OEM shocks are pretty weak.
