Outaline
You have a dirty, whorish mouth!
Coming along nicely
Truck looks good man. On the drive shaft issue find a good reputable shop and give them the dimensions that they ask for. It is quite simple instead of lugging the truck all the way down their. May take a few days for em to make you one up.
On the brakes disconnect the abs sensor, than reconnect em. After you do that than diconnect the negative battery cable to reset the pcm. Leave the cable off for 5 mins or so and that should clear it.
On bleeding the brakes it will bea two person job. There is no set on how much fluid it takes. It will take as much as needed to get the job doen and have a pedal. First you make sure the screws on the brake lines are all tight. Than you fill the brake resevior up and go to down. Have someone in the truck that will press the pedal to the floor. Go to a brake line and open it up with a wrench while the other person is still pushing down on the pedal. You will than close the screw and let the pedal come up. Do this several times on each one to clear all the air out. DO it one time after you have nothing but fluid coming out of the truck. Than move on to the next one and do the same. Make sure the resevior does not run out of fluid. Or you will not have a succesful attempt at this lol. Looks good man! Hurry up and do the rear and throw on some 46's!![]()
Yeah i got a few shops im going to call about the driveshaft thing. How long should bleeding the brakes take? How much fluid should i buy?
