New Dominator Coolant Boost
AMSOIL is coming out with a new product, Dominator Coolant Boost. It is a good alternative to Royal Purples Ice and Redlines Water Wetter. As stated by AMSOIL "Dominator Coolant Boost is formulated
with proprietary tiered surfactant technology,
providing quick and effective heat transfer
inside radiator and cylinder heads, which
results in reduced operating temperatures,
more efficient operation, increased horsepower
and significantly reduced engine warm-up times in cold
weather. Coolant Boost also contains a robust mixture
of corrosion inhibitors that protect the radiator, heater
core, water pump, cylinder heads, engine block and
intake manifold from the damaging effects of corrosion."
Temperature Reduction
Dynamometer Test
To test the temperature reduction capabilities of
Dominator Coolant Boost, dyno tests were performed
on a Chevy 350 cubic inch engine with an aluminum
block and cylinder heads. Running the test with both
straight water and water treated with Coolant Boost,
the engine was operated at 4,500 rpm until coolant
temperature stabilized.
Stabilized Coolant
Coolant Mixture Temperature
Straight Water 221°F
Water with Coolant Boost 202°F
Test results show water treated with Coolant Boost
provided a 19°F temperature reduction.
There is also going to be a price increase Aug 1st by 3 to 6% due to the increasing cost of raw materials.
sierra
ZZZZZZZZZZZZZZZZZZZZZZZZZ ZZZ
UP of Michigan
Nick,
They just said Friday there is a logistical issue and it won't be available till the week of July 26
Shanks12
Will You Join My WolfPack?
Fishers, IN
Have you personally used this yet?
or if you don't mind me asking.. whats a bottle of this run?
This is mainly designed for racing applications right?
The retail price for a bottle is $11.10.
Yeah it will not be available until after the 26th of July. It is brand new and so I have not used it.
Shanks12
Fishers, IN
Well that doesn't sound so bad...
So this is for racing applications only? I'm not real familiar with Amsoil products
sierra
UP of Michigan
Here is what it says in the July issue of the AMSOIL Action News
Recommendations
Dominator Coolant Boost is recommended with both racing applications using straight water coolant and automotive applications using 50/50 coolant/water mixtures.
