Winch suggestions
slims
gonzales LA.
After getting into a situation where a winch was needed the other day, iv been thinking of what I want to get. I used a hitch winch the other day and it got the job done. Idk if I want to rig one up in the front or get one for the back. What yall think? Pros and cons..
Darkanion
Moar lift.
Bigger tirez!
Get farther in before you get stuck! :thumbs: :crackup:
slims
gonzales LA.
If I would have kept my foot to the floor I wouldn't have got stuck. As soon as I let off the gas I sunk. Lol
Sent from my SAMSUNG-SM-G890A using Tapatalk
Bumper mount (front) for off-road
I have winched out of nasty shit more times than I can count, I like going forward when possible and steering. I usually had buddies pull me backward or they would anchor and winch me backward if I couldn't go forward.
The rules of buying a winch are simple; buy twice as much as you need :lol:
I have wasted enough money for the both of us on that mistake.
Those Nissans weigh what...6000 pounds? Get at least a 12K, or 15K.
I had a 9K on my rock Jeep, and I could dangle that thing off cliffs :D2
I need to find pictures, and scan them. Yes, it was that long ago :GASP:
Darkanion
:lol:
At LEAST double the winch you need... You may need to tie the back of your vehicle to a tree and pull something heavier out, lol.
I need to save up and build mounts for a 20k, if I can find one, for my truck, lol.
NMRam
Ft Sumner, NM
If it was me, I think I would try to find a front receiver hitch (I'm not sure what's available for a Titan) and then set up a receiver mounted winch that you can move front to rear. You can wire it so you have a plug at both ends and you can move the winch to best fit your recovery situation.
There are a couple things to consider with that, though. A 10-12k winch mounted in a receiver tray is HEAVY. It's not something you want to be lugging around all the time. Also, with a receiver mount, you can bend them if you pull at an offset angle. You will need to be careful about pulling relatively straight forward or backward.
Just my $.02
gerryride
^^ That seems a better route, especially considering the extra weight they.
Martin
