Wheel stud replacement?
mhockey9090
Just an easy simple question. Would i be able to do this in my driveway or will i need to have the hub taken off in order for it to be pressed in and out? Has anyone done this to their F150s ? Its going to cost me around $100 to have someone do it for me but if i can save by going to autozone and getting a loan a tool from them and do it at home i would be more than happy too.
ProZach
Its a fucTMCTMCTMCTMC BRONCO! not a Jeep!
Chandler
If you have a decent amount of experience and confidence its a fairly simple process. Plenty of videos out on it (youtube). I was gonna do it to my ranger but my mechanic did it free of charge when he installed my lift.
mhockey9090
Yeah i installed the lift on the truck so thats not an issue. Just dont have a floor jack, big enough jack stands, or a torque wrench to use. But taking off a brake caliper and rotor is easy enough then i see people use hammers or c clamps in order to get them off and on.
Getting them out is no biggie. I've always used the lugs and a breaker bar (no air) to reinstall them. Never had any problem.
NGM7492
Changed
Tallahassee Fl
I would buy a couple of lug nuts just to use to pull the lug bolts through. Put a drop of oil on the lug bolt threads and put a few flat washers between the lug nut and the flange with a little oil between them to make it easier to pull the lug through. If you have to grind a corner of the lug off to get it to slide into the flange thats fine too.
mhockey9090
Looks like Mixbreed will be coming out and helping me this sunday. Will post pics for sure
