I ran across this last night and wanted to get some feed back from our group. I am interested in hearing what you guys think about it. Is this another gimmick or is this something worth trying? Discuss.
Port & Polish Throttle Body
A home-ground throttle body is an easy way to get more air into the Gen. III engine. To perform this procedure, unhook the throttle position sensor (TPS) and idle air control sensor (IAC) connectors from the throttle body. The throttle cable and coolant hoses are removed also, then the three 10mm bolts holding the throttle body were removed.
The TB was taken to a workbench and mounted in a vise; a carbide bit and some 80- and 120-grit paper rolls were waiting for it. Porting the Gen. III's throttle body is done to remove a restrictive ridge in front of the throttle blade and to generally make the contours smooth. You want to take out the turbulence and increase velocity, but don't go hog-wild because the carbide bit can burn through pretty quickly. Use the 80-grit to smooth out the carbide burr cuts, and the 120-grit to polish the throttle body smooth.
Any sharp edge on the throttle body should be buffed down.
don't do heavy porting in the idle air bypass area--that will force air into this spot that doesn't need any more.
Mild port work is performed on the back side as well, and the throttle blade screws are ground down. Once the TB is cleaned up, it is ready for reinstallation.
I don't forsee much gain though.
