Just want to bring this back to the top for the new individuals. The AMSOIL look up has some pretty good info in it about your vehicle that you could use and not just for AMSOIL products. Wix filters, NGK spark plugs and Trico wiper blades. You can print the info out and keep it in the glove box. Oh and there are torque specs as well and grease points listed.
I guess I can bring this to the top every now and then for new members.
Instead of scrolling to the top I just put the info on here, read below.
If anyone wants to know what their vehicle specs for fluids, Wix filters along with AMSOIL filters of course and capacities and drain/fill plug torque specs, spark plugs if you use NGK along with Trico wiper blades.
Click on the AMSOIL Synthetic Advantage banner, which takes you to my web page, then down in the middle of the page, click on AMSOIL Corporate Website. Once there look to the right hand side of the page and you will see this
PRODUCT LOOK UP GUIDE
Auto and Light Trucks
PowerSports Lookup
Small Engine Lookup
TRICO Heavy Duty
FILTER LOOKUP GUIDES
Vintage Vehicle
Heavy Duty Lookup
OIL COMPARISONS
Motorcycle Oil
Gear Lube
Motor Oil
Performance Tests
CROSS REFERENCE GUIDES
Compressor Oil
Master Filter Cross
NGK Plugs and Wires
INSTALLATION INFO
By-Pass Filters
WIX Cabin Air Filters
MANN Cabin Air Filters
MISCELLANEOUS
Gear Lube Chart
Two-Cycle Chart
MSDS Sheets
Pick the guide of you choice and fill in the required information.
Or you could just click here for the Corporate Website and go from there.
You can also print it out and keep it as a referrence.
