Urgent question on '91 Jeep Wrangler
ProZach
Its a fucTMCTMCTMCTMC BRONCO! not a Jeep!
Chandler
anyone ever had a stick shift snap on you? like the entire upper half just falls off?
This happened to me today on the jeep I'm borrowing and I need to find a way to fix it. It's not entirely clear in the pics but the part the broke off wasn't even the threaded area. from all I can tell is there used to be something to thread into (it was gone when I started borrowing it) and now not only is that part gone but this was such a clean break that the part it could fit into is filled with the rest of the shifter!!!
any suggestions?:ohnoes:
here's da pics
NMRam
Ft Sumner, NM
Looks like you need to buy an easy-out and lots of penetrating oil. If you can get the broken off piece out, there may be enough threads left to get the shifter to thread back in. Otherwise, I guess you will have to hit up a wrecking yard and try to find the shifter and linkage.
Looks like it wasn't seated all the way and the flexing at the threads eventually let it snap. Luck you!
ProZach
Chandler
could i ghetto rig it and have i welded on (safely)?
stat91
