Wow, this technology is moving forward and fast, most trucks by 2010 will be using this system, and in my mind what a pain it will be for use diesel owners. read the article below, urea freezes at 11F and turns to ammonia on its own at 120F, there is a tight range of temperatue control there. Its going to require coolant lines to be run to control the temp of the fluid to keep it optimal, other wise, your truck may not start. yeah i said that! I cannot imagine doing the work i do running this system on a diesel truck ever again! I live in a cold climate, sometimes i have to work in "the bush" for long periods of time, and in cold weather the trucks have to keep running. DPF (diesel particulate Filters) are bad enough as my company has two new dodge trucks with this sytem and they regulairily are having issues with exhaust restriction due to poor catalyst performance.(mostly due to long idling times and also high idle belt driven air compresors that we regulairly use.) I am also getting a new 09` ford in the new year and fear the troubles i may forsee. yet this may pale in comparison to these new systems. If i were a company running a fleet of deisel trucks that run in these conditions i may take a high consideration into getting a gasoline vehicle, and suffer the redued power and economy, just to have reliable trucks to serve my customers... I want to know what other diesel owners think of the issue at hand, will it make you seriously consider getting a new diesel if you are in the market?
http://news.pickuptrucks.com/2009/0...reviews-nox-reduction-solutions-for-2010.html
i`d also like to say i am very glad we are striving to save our planet with these technologies, but i fear we may be choking ourselves literaly in the end.
