Transmission annoyance!
My problem is that I can't shift from 2nd to 3rd gear at high rpms...
Specifically, when over the 4000 or so RPM mark... Which means I can't do 0 - 60 runs, as 2nd tops out at just under 60 MPH, I can't do 1/4 mile races, and in general, is a major PITA when climing hills, too.
What might the issue be?
So far as I can tell, it's only the 2 to 3 shift that's the problem... 1st to 2nd has no issues... I don't believe there's a problem with a 3 - 4 shift... But it's been a long time since I've tried winding out 3rd gear... :dunno:
If it's something major... I'll have to see what I can say to the dealership to have it fixed on extended warranty... :lol:
is it getting worse?
It's not really getting any worse... I don't think, anyway... But it definitely hasn't gotten any better :lol:
Syncros?
Just skip 2nd when shifting. :D
Kinda defeats the purpose of attempting to fix the problem :lol:
Though, I should see if it's high RPM from any gear that stops it from going into 3rd...
Stumpuller6.5
Shits gonna get Abrasive...
Canukian Land
syncros man, try running a different fluid, maybe a good synthetic, or lighter weight. :thumbs:
It's the GM specific fluid for my transmission :dunno:
It's been doing it since I bought it.... at 49xxx km... On factory fluid.
Lately it's had a couple random problems getting into 1st gear...
I don't think it's a fluid issue... I think something is either bent, because I discovered today, that I can go from 5000 RPM in 1st gear to 3rd with no issues...
It seems to be only when going from 2nd to 3rd, and 4th to 3rd... Gonna take a drive tonight where I can romp on it and do some testing.
So far syncros is all I can think of, as well.
Stumpuller6.5
Canukian Land
i had a buddys manual trans appart on time, it was out of a geo tracker, all that kept the forks on the shafts was dinky little cotter pin, one had broke and we replaced it, maybe the same case they could be worn. :dunno: was a prety easy fix in the geo, it only weighed about 80lbs. :D
grimey01
