Transfer case 241C that freezes
Discussion in 'TMC TECHNICAL' started by HelmuthHyun, Jun 30, 2019.
  1. HelmuthHyun
    HelmuthHyun I'm NEW... What now?
    Norway
    Hello everyone.
    This is my first post and I hope not to be ot here.
    I have a problem with the TC 241C.
    When I insert the 4 drive wheels, the truck moves 1 meter and then locks.
    Reverse gear is also locked.
    I have to remove the 4 drive wheels, turn off the engine and the system unlocks.
    When the truck stop, I don't accelerate because I'm afraid of causing damage. Perhaps it is useful to know that, a couple of months ago, I had to open the front differential to change a worn washer (I had lost oil from the differential). I repaired and everything worked properly.
    The TC outside is covered with mud and oil and I think it has lost all the oil.
    Can lack of oil cause a blockage? Perhaps the internal forks are worn out?
    I remember forks have some plastic insert.
    Tomorrow I will check oil level and, eventually, refill oil.
    Someone had same problem?
    Thanks in advance to everyone answer!
