Torque specs?
buckshot85
Hampton S.C.
Does anyone know what the OEM torque specs are for the top of the shocks are for my 2009 GMC? Going to be installing my leveling kit after supper and wasn't sure. The leveling kit says 40lbs but i wasn't sure if the Nut's on top are the same specs.
15 ft lbs for my '01 top mounting nut, and 19 ft lbs for lower bolts on 2 wheel drive, 59 ft lbs on a four wheel drive.
My Haynes manual only covers up to '06, so I don't know if it's different on yours. This should give you an idea though. :dunno:
:dunno:
Shock Absorber Module to Frame Nuts
50 N·m
37 lb ft
Shock Absorber Module to Lower Control Arm Bolt - 1500 Series
50 N·m
37 lb ft
Shock Absorber Electrical Connector
20 N·m
15 lb ft
Shock Absorber Nut - 1500 Series
890 N·m
59 lb ft
