Ticking..
C
Cashezo
No I'm not making this up. Truck was parked in my garage for about 2 days. I started it up, everything seemed fine. Drove it out. When I gave it some gas and the RPMs climbed, I started to hear a ticking noise. Noise was not loud at all, but you could definitely hear it. It has done this once before when we were installing the navigation system and drove it out. I'm not too worried as I will most likely sell it sometime next year and upgrade to the Platinum model. Oil changes were done by GM when the OLM reached around 10%. Used regular oil so far, but I'm pretty sure I will start to do my own oil changes from now on and switch to Mobil 1 Synthetic. See if that eliminates the problem or not. Should I mention this to the dealer?
edit: Forgot to mention that the speakers stopped working as well. Pulled into a gas station, turned the truck on and off and they started working again!
CJ Hungus
Moderator
Ham Lake, MN
Does this happen shortly after you start it up?
C
Cashezo
Yes. There is absolutely no ticking noise when I start it up, but when the RPMs begin to climb, then I can hear the noise. Could low oil cause this? There are some pretty dumb mechanics at the dealership where I get it serviced.
CJ Hungus
Moderator
Ham Lake, MN
Hmmm, I would guess it is just noisy lifters. You could mention it to the dealer but I would guess they will just say "It is a normal operating sound"
C
Cashezo
But say something malfunctions down the road related to the lifters, will they repair it no charge?
CJ Hungus
Moderator
Ham Lake, MN
Well they better, otherwise you can chuck your 100k mile warranty out the window
Ramjoe
Moderator
Northeast PA
well this isn't even worth a response but here it goes....Take it to the Dealership and see what happens.
grimey01
