I have 2000 silverado,This morning I turned on my truck and none of my dash lights are working or crago switch light,I checked the fuse and all are good,not even the headlight switch light is Any ideas Thanks
I do not have the schematics to that part of the truck. I will try and dig something up.. even tho I am not on my A game at the moment.
Is it the brightness just turned all the way down? It sounds stupid but in sunlight with them turned all the way down they aren't visible.
pop the dash out and see if the plug to the light switch came loose, the switch could be bad if all fuses are okay. did you check the fuse panel left of the dash (door open?)
I have checked all the fuses under hood and side of panel,Im thinking mabe dimmer switch but not sure will replace and hopefully that will work
If dimmer switch was bad would it still make the lights turn on ,on the back of headlight switch there is a green wire thats suppose to be hot but it's not any idea how to trace wire to see why its not?
