Service 4WD MIL
I recently had a message run across my Drivers Information Center (DIC) it said " Service 4WD"? Anybody got any ideas here?:dunno:
*** 2006 Chevrolet Silverado, Crew Cab, Z71, 5.3l.***
OPGMC
im sure theres a message somewhere there:dunno: I dont know realy, what year is your truck again?
Stumpuller6.5
Shits gonna get Abrasive...
Canukian Land
you can have it scanned to pin point the problem, other wise check out the connection on the encder/motor on the side of the t-case. it could have loosened, i have also seen the boot for the shaft rub a hole in the encoder, silly really but it happens. did you try uing the 4wd recently?
It's not throwing any codes, when I start the truck up the 4WD selector switch goes through a series of light flashes and then goes blank. It will not go into 4WD, I have checked connections and didn't see any bad wires or anything like that. It's just staying in 2HI, I guess if it was gonna stop working that would be the gear to be in at least. :dunno:
Stumpuller6.5
Canukian Land
it will not throw a CEL and you need a good scanner to read the module controlling the t-case. but most likley failed switch, but i`ve changed just as many switches as i have encoder/motors:dunno:
R
Riggs
i think a lot of people have had problems with there 4wd switches, but i would scan it to make sure
grimey01
