Seafoam
I used it a while back when I heard some people say it gets rid of the cold start knock on GMs. It did absolutely nothing but piss off all my neighbors for smoking up the neighborhood. I noticed zero improvements on anything at all.
Tucson Z60
:lolup::lolup:
Yep I agree.....Spend you money on gas because you will notice difference between having gas and not having gas.
Just my opinion and not going to fight about it......I personally think that the stuff is Snake Oil.
Also if your sucking into your intake vyour pulling in a large volume of fluid, if to much goes to one cylinder you could end up hydraulicing a cylinder which means a bent rod or crack/broken rings. Also if it's breaking stuff away in the intake does thins stuff make it out the exhaust or get stuck in valve seat (most likely why some run like crap for a few days) and then get lucky when it works loose.
Sorry man no thanks!! A big can of brake cleaner squirted inot the intake system via a vacume hose will do more good for a cheaper price. In carb it can break loose materials and then they get stuck in the needle and seat. Then you need to take it apart or you can get lucky blowing a carb or brake cleaner down the bowl vent.
As I said all just my opinion on this stuff....Everyone has one and you know what they say about that :cheers:
If anyone thinks different about the stuff That is my disclaimer to not blast my post and you can post your opinion. No reason to fight about something that were not going to change opinions about. :tmc:
svensk
TMC's official Zombie Slayer
You betcha
I've never been a fan of magic potions, but some folks swear by the stuff.
It's not a magic potion, it's just a carb/injector cleaner... :dunno: My lawn mower and snowblower sure as hell see a positive difference when I started using it as a fuel stabilizer.
bubbatrucklover
Heavy Metal Red Neck
Jacksonville,Fl U.S. of A.
I used it once on our car and twice on my truck. It smoked alot on the car and didn't notice any improvement. Both times on the truck little to no smoke and no noticebale fuel savings or better operating conditions.
I've heard 50/50 from no improvement to "wonderous" results. IMHO it's less then $10 dollars and worth a try.:dunno:
I used it on my service truck a couple of years ago. I think it gave it a little more response, but that's about it. :dunno:
