Repairs
Alljackedup408
Shut Up Stupid
Titusville FL
99 silverado 1500
Been through about 4 u joints.. finally ponied up and got the high dollar ones.. zero issues in 30k miles... f them cheapies from the parts store lol
4 wheel drive switch on dash ( common GM issue )
Torque converter stator let go... so i rebuilt the trans while i had it down and stuck the goodies in it, and had the converter rebuilt.
and thats it... i cant complain.. truck has been very good to me.
2001 Chevy Suburban
Bought in jan, 2006 with 51k miles on it (currently has 72k miles on it)
summer 06- steering shaft clunk became quite obvious, self repaired by regreasing it
because my GODDAMMED extended warranty wouldnt cover it as they said
regreasing it is a "maintenance issue", they would only cover it had it failed.:fume:
Summer 2006- fuel pump harness was replaced under recall
Early 2007, clunk returned and I then switched the steering shaft to the "new greaseless"
model, self installed, got the part for free from a friend who worked at a chevy dealer.
The clunk returned less than a week later and just never did repair it again.:fail:
Feb 2008, power window switch, power mirror switch went bad, dealer replaced under my
extended warranty:)
Feb 2008, drivers power door lock actuactor would only work if the temp was above 40
degreez outside. (For some strange reason when it warmed up, it bagan working
again):confused: Dealer replaced under ex warranty after finally witnessing it happen
on a cold morning when I took it in, they saw it working just days before.
Nov 2008, started to hear a clunking sound from the rear (I assumed it was the suspension)
Jan 2009, Finally took it to the dealer to see about the clunking (as my extended warranty
expired at the end of this month) I also asked them to go thru the truck with a fine
tooth comb and let me know of any other issues. They replaced the steering shaft (as
the shaft had actually failed it ,wasnt a greasing issue:pfingers:) under warranty and
they said the clunking was because my rear end needed a rebuild. They said all the
bearing and pinion gears were shot. Warranty did not want to cover it at first until
they sent an "appraiser" to see the damage for himself. They finally footed the $2800
repair bill. Dealer also changed the parking brake shoes (at my expense) and they
offered a 60% labor discount as they had the rear end and axles all apart anyway.
Total cost for brake shoe replacement was 163$, ($120 was for the delco brake
shoes)
June 2009- Rear drivers side window regulator went out, still have not replaced it yet (if it
were a front window it would be repaired by now) Only the kids sit back there, and
my AC is working fine, so I'll repair it when time and money permits, as the part is
over $170 locally and $130 is cheapest I found online.
July 2009- drivers door lock actuator began acting up again. Sometimes it works, sometimes it
doesn't. It doesn't seem to be temp related this time as its 90-100+ degrees every
day recently. Tested the switch and wiring to the actuator, all ok. I'm clueless as
why an actuator would do this:dunno: (so were the dealer techs last time).
Other normal wear and tear items (which I usually wouldn't consider a "repair") include replacing the tires, battery, oil and filter,air filter, fuel filter, light bulbs , wipers, etc
I forgot to list my latest repair. I had to change the ambient light sensor (the sensor on top the dash for the auto headlights). The sensor cost me 14 dollars with tax, and I had it changed out in less than an hour. So far, except for what I would consider normal wear and tear(tires battery, brakes, etc.) I'm out less than $100 in parts for the repairs I've done. I'll have to shell out some money to fix my window regulator though, but that probably the most expensive repair I'll have to foot the bill for so far. Not too bad for having the truck well over 3 years now.:thumbs:
02 Silverado Z71 extended cab now has 85k on it bought in Sept 01.
-Not sure of the date but had the radio replaced under warranty
-Nickle plated yoke due to noise, replaced under warranty
-Driver side door speaker kept falling out of mount, replaced under warranty
That is it. I put a Big Block 70 series Flowmaster on it when I got it in 01 and just now had to replace it. It was rusting out on the bottom.
Cowboy Cadillac
Ain't no trash in my trailer!
Grande Prairie, AB, Canada
01 Sierra has 125000K Bought with 82000kms( from parents, and yes I actually paid for it!)
Replaced fuel pump, Once 12/27/07, and again 1/13/09
Had throttle body changed (warranty)
Both window regulators One in 04, other in 06
U joints and rear diff seal at 100,000k
A/C tensioner pulley( still in box to be repaired)
Needs balljoints (you can lose a Honda in our potholes)
Needs rear bumper( towing accident...ALL BAD)
All 2wd...
'04 GMC 2500HD 45K on the clock
6.0L SLE CC SWB
-'06 20Kmi Radio quit working, repaired under Warranty
-'06 20Kmi I-shaft under warranty
-'07 25Kmi Auto Dim Review Mirror would always stay Dimmed, repaired under Warranty
-'08 30Kmi Rear U joint squeak, Repaired under Warranty
-'09 40Kmi Right Rear door trim come apart. Center console lid cracked, Replaced under warranty
'01 Chevy Blazer Wifes Mail Truck 50K on the clock
4.3L 4door LS
-'08 35Kmi Transmission blew, Mechanic repaired
-'08 Unk Spider Assembly failed, Mechanic repaired
-'09 40Kmi Intake Gasket, Self repair
-'09 45Kmi Fan Clutch,Self Repair
-'09 50K Fuel pump wiring self repair
'98 GMC 1500 Farm Vehicle 160K on the clock
Mighty 4.3L SL SC LWB
-'04 to '06 Unk Intake Gasket , Upper and Lower ball joints, Tie rods, Drag Link, pitman arm, idle arm, water pump,,fuel pump self repaired.
-'08 125K Trans Slipping, Still riding on it Radiator Busted, Looking for replacement..Yes still looking, jut have to keep filling.
New repair.....
Texas Jim
Ft. Worth
1999 Chevy Astro with the old reliable 4.3
Bought new ...it burned up in my garage fire in Nov '06 with a little over 250,000 miles.
Water pump at around 150,000.
Alternator at around 175,000.
Thats it.
2006 Chevy 1500 Express...bought new to replace the Astro van.
Currently has 72,000 on it.
Never been in the shop for anything.
At least not yet. :D
Just change the oil, put gas in it and drive it.
Everything on it is still OEM.
GM Trucks ROCK. :D
:thumbs: :cheers:
Stumpuller6.5
Shits gonna get Abrasive...
Canukian Land
I dunno why i never listed my trucks in here. my first truck was the 51 chevy, it ran and drove fine when i bought it, but my dad and i DID A full RESTO, every nut and bolt was turn and/or replaced. the only things we left were the trans and rear axle and steering box. everything else was replace, rebuilt or repaired to work. ir cost $11,500 to do including paint and mechanical repairs. but is worth probly 3 times that.
my next truck was a 1980 GMC K2500 350ci RCLB. It had all new gm panels put on and was a nice lookin truck, was fun to drive but what a lemon. bought it for 8k and when i hit 8k in repairs i sold it, many things including rads, clutches, differentials, wiper motors, engines, and lots of wiring had to be replaced too many times.
my current truck 98 K2500 ECSB 454ci, had the idler and pitman arm, rh upper ball joint plus alignment done under warranty at 45k kms in 05`, had to replace front pads (my cost). then in 06` starter finally died (it had always sounded bad) had to change that in the save-on foods parking lot in the middle of winter, at least it only takes 10mins!) also had to change the fuel pressure regulator and injectors (common issue on L29s) i have had to change the reg 2 times since then and injectors once more, but finally got smart an installed bosch injectors (good move! :thumbs:) I had to change the batteries in 08`, i let them run down while camping one weekend and they never did come back to life fully. when i installed the supercharger i replaced the seaping intake gaskets. i recentley have replaced the rear shoes and drums, they wern`t quite toast but i was chasing a weird brake pulsation (which turned out to be rotors, still on order, and i will be installing new pads) and i just replaced the rh upper ball joint again and both lower ball joints. I think thats about it. i have had to replace the G80 as i exploded it, (but that was not under normal wear and tear, it was under sever supercharger abuse, lol) I can`t belive i haven`t had to replace any u-joints. :fingersx:
i may need to do oilo cooler lines soon they are getting wet. they are very easy to do on a 454, much easier than a 350 or the same year.
Dankle 666
They call me Randy...
Molesto, PRK
2004 GMC Sierra 1500 4.3L 2wd.
~25,000 mi - Faulty distributor (?, IIRC) which caused the truck to stall when coming to a stop. Replaced under warranty.
~30,000 mi - Something in the steering replaced due to clunking sound when turning. Replaced under warranty.
Brakes several times and a set of rotors from driving like a jack ass and doing brake stands almost every day. Coupled with a lot of heavy braking from 100+ and a lot of bay area driving.
I went through 6 tires in the 2 years I had the truck.
When I traded it in it was riding on a spare and 3 bald tires, the transmission slipped horribly, only 1 tire would burn during brake stands, and I had it buried in deep mud several times. :lol:
GM trucks are fun to abuse :D
2004 F150 4.6L 2wd.
90,000 mi - Replaced driver side window switches. $64 and 2 minutes to fix.
112,000 mi (went in today) - New transmission. $2400 OTD w/ 3yr/100,00mi warranty. My original transmission still works in all gears except 4th (O/D) but I couldn't find any shops willing to open up the tranny @ 112,000 miles and replace the O/D snap ring. :fume:
So far with my 07 all I have had is the slip yoke clunk. 10 minute fix in the driveway. It has been the best truck I have ever owned so far! I'm keeping my fingers crossed.
Texas Jim
Ft. Worth
2006 Chevy 1500.
78,000 miles.
Had to work on it today for the first time.
Drivers side front turn signal bulb failed.
5 minutes to replace.
If this thing keeps giving me trouble like this, I am gonna have to trade it for something else that is not always having something wrong with it.
It should last longer than that before having to work on it.
:jester:
:jester:
:jester:
WillieT
