Recall: 2004-2005 Tundra: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM
07FX4Chick
LIFETIME SUPPORTER
Des Moines, WA
[FONT=&quot]NHTSA #: [/FONT][FONT=&quot]69677,69678[/FONT]
[FONT=&quot]Make: [/FONT]
[FONT=&quot]TOYOTA
Model: TUNDRA
Model Year: 2004-2005
MFG Campaign #: 50E
Description: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM
Manufacturer that filed defect/noncompliance report: TOYOTA MOTOR NORTH AMERICA, INC.
Begin Date of MFG: 8/1/2003
End Date of MFG: 12/22/2004
Vehicle, Equipment, or Tire report: V
Number of units affected: 5,726
Date owner notified by MFG: 5/31/2005
Recall Initiator: MFR
MFG's of Recalled Vehicles/Products: TOYOTA MOTOR CORPORATION
Defect Summary: CERTAIN PICKUP TRUCKS EQUIPPED WITH BOTH VEHICLE STABILITY CONTROL (VSC) AND THE TRD DUAL EXHAUST SYSTEMS. THE TRD DUAL EXHAUST SYSTEM MET ALL CLEARANCE SPECIFICATIONS ON MODELS WITHOUT VSC, HOWEVER THE DRIVER'S SIDE EXHAUST LOCATED IN A POSITION WHERE CONTACT BETWEEN A BRAKE LINE FOUND ONLY ON VEHICLES WITH VSC AND THE TRD EXHAUST PIPE MIGHT OCCUR.
Consequence Summary: IN THIS CONDITION, THE EXHAUST PIPE FLANGE MAY RUB AGAINST THE RIGHT REAR BRAKE LINE, WHICH COULD CAUSE BRAKE FLUID LEAKAGE. THIS COULD LEAD TO AN INCREASE OF VEHICLE STOPPING DISTANCE, WHICH COULD RESULT IN A CRASH.
Corrective Summary: DEALERS WILL INSPECT AND, IF SO EQUIPPED, WILL REPLACE THE TRD DUAL EXHAUST SYSTEM FREE OF CHARGE. DURING THIS REPLACEMENT, THE DEALER WILL ALSO INSPECT THE SPECIFIC BRAKE LINE TO ASSURE IT HAS NOT BEEN DAMAGED AND REPLACE IT IF NECESSARY. THE RECALL BEGAN ON MAY 31, 2005. OWNERS SHOULD CONTACT TOYOTA AT 1-800-331-4331.
Recall Notes: TOYOTA RECALL NO. 50E. ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).[/FONT]
Casey1122
