64shortbed
TMC 2013 NASCAR CHAMPION,
As you guys know i have been gathering parts to do my brake up grade on my 64 gmc. I have all the parts for the front disc brake up grade and have decided to gowith the 5 lug bolt pattern so i can buy all my parts in the future over the counter using factory parts instead of haveing to order them from a aftermarket place. Now i need a little help IDingthe 12 bolt truck rearend i got from a friend. He said it was out of a 2wd suburban but was not sure of the year. So here are the numbers i found on the rearend and ring gear.
Axle tube numbers KAC W023 2.
These are on the center housing A166, 3896839 N, and GM69.
These are on the ring gear 381779, 14:43, GM 01762.
I know the 14:43 is the ratio which is a 3.07.
I'd like to know the year if posable. Thanks for any help in advance.
