Quik's '02 twin turbo RCSB
Q u i k
Pittsburgh,PA!!!!
Little run down. Truck started off as a 5.3/60e/373 LS trim package silverado. As years went on the truck has transformed into as you see it today. Over the years it has had several motor combinations. It went from a stock 5.3 that ran 14.6@94 to a 5.3 on 75 that ran 13.3@104 then a LQ9 swapped in along with a built 60 and 3800 stall, then a 408 with a T56. In 08 i built a single turbo setup and used a 4.8 which made 702 rwhp. I ran more psi but never redynoed. So i tore apart that build and wanted a set of twins. So i sold off the old setup to a good friend and built a twin setup.
Great job! :thumbs:
Got any videos for us???
DV2000NJ
The Browmaster
Central NJ
What's up George, glad to have you over here. :thumbs:
I can NOT wait to see this thing finished.
Q u i k
Pittsburgh,PA!!!!
instead of just angling it as alot of others have done, i decided to put the extra bit of effort into it and do a offset
CJ Hungus
Moderator
Ham Lake, MN
How big are those turbos you are gonna run?
Never mind, I saw them in the other thread. :thumbs:
Q u i k
Pittsburgh,PA!!!!
now im sure some of you are interested in the specs of this motor
well heres the specs on this bullet
2005 LS2 with 25k
WCCH stage 2 317s
crane gold 1.7 roller rockers
7.250 crane push rods
LS7 lifters
06 6.0 self ported/shimed oil pump
self ported fast 90 with RTV mod
LS2 MLS head gaskets
ARP rod bolts [reused from 4.8 setup]
SLP double roller timing chain
230/236 591/602 115+2 custom cam
GM TTY head bolts
LS7 Valley cover
LS7 manifold gaskets
3400 v6 manifold studs
this bullet is sitting about 9.85 cr since the 317s are 74cc, turbos are 62-1 turbonectics, 1 7/8 primary headers, merizere EWP water pump, SLP 25% UD pulley​
Jesse S
