I got a set of Quickjacks and this is the first time using them on our Suburban. It lifted it with no issues at all. I need to pull in the garage farther or turn the vehicle around because I just had enough room to lift it off the tires before the back of the suburban would hit the door opening. I highly recommend these. Super easy to use and store out of the way. While I was rotating the tires the exhaust had a small vibration when we first started the burb. Turns out the clamp right behind the last CAT was super loose. Well it was rusted to the point that I couldn't tighten it down so $34 dollars later and a new clamp it is tighter but not as tight as I would like it to be.
