dirtyoldman
My Burb,like all ATs has cooling lines to the radiator but it also has engine oil lines to the radiator.I'm thinking those lines could be run to seperate coolers and eliminate the radiator.I have two aux. tranny coolers but no aux. engine oil cooler.Does the radiator cool the two oils or do the oils add to the radiator temp.Would the engine temp run lower if I eliminate the radiator? and if so does it make sense to do this? Right now it's near 100* almost on a daily basis and I know heat is a big killer of everything under the hood...
,I didn't mean eliminate the rad.,I meant to eliminate the rad. from doing double duty
