how do you change it? How do you check it, I get a noise everytime I turn the wheel one way, I am guessing thats what the issue is, low fluid...
Pretty neat pump.I have the PL-650 Pela. I had it to change the oil in our inboard Bayliner. Got rid of the boat and kept the Pela. It works great to change the oil in the lawnmowers, power steering, and even pull transmission fluid out so that it doesn't make a mess when you drop the pan. Also good for sucking out all the old brake fluid when you change it out.
Pela PL650
I changed mine when the pressure line split, and again when the pump cratered......ive got 2000k on the new one.
