Overdrive help
davbell22602
Stihl Chainsaw Man
Bunker Hill, WV
1995 ford f150 xlt 302 automatic
Overdrive disengaged itself driving the other day. Drives and shifts fine when not in overdrive. Just geared awful low. Overdrive light flashes off on the gear shifter lever on the column. Cant get overdrive to come back on. Overdrive relay? Speed sensor? Whats ur thoughts.
hotrodpc
Did you ever get this fixed Dave? What did it end up being? I'm sure it's electrical and should have been a relatively easy fix. Just a matter of tracking it down. I could even be the button in the end of the shift stick. Should only be one OD solenoid.
Casey1122
