Ordered An ALDL Cable
Texas Jim
Ft. Worth
I was looking over the chart you posted...
If it will let you add more TOTAL timing, that might be a good thing.
Not more "INITIAL" timing... that might make it hard to start and cause it to KICKBACK...but more total timing that it could use when just cruising down the road.
dirtyoldman
Saugus,Ca.
That printout was from an idle,so the total timing wasn't seen.I revved it up a bit and in another graph it showed the total timing upwards of 35*.All that info is on my laptop and since I'm on my desktop right now I can't access it.I'll be trying to see if I can somehow show that graph.It's pretty interesting how this old OBDI system works,complicated even for it's old age.
There's another program called Tuner Pro RT that has some king of device that you attach to the EPROMM and from that you can make changes to the ECM and have the results in real time while you drive the vehicle.I'm looking into that also....
Texas Jim
Ft. Worth
OK... that's good then... 35 degrees total is about right.
I was concerned about the 15 degrees... that isn't very much... :lol:
dirtyoldman
Saugus,Ca.
I tried to copy a screenshot of the program window but when I went to paste it to ''paint'' the ''paste'' word wans't available,any ideas?Talking about my laptop now...it's an old Gateway
Texas Jim
Ft. Worth
See if you can paste it into MS WORD...
Sometimes that works when nothing else does
Well I got Datamasters to work,now I just gotta learn how to use it.Here's a quick printout of some of what it can do.
Pretty cool what can be done electronically these days!
Hey Gary!
dirtyoldman
Saugus,Ca.
OK,I'll try that.But it's gonna have to wait 'til tonight....gotta get to work in a couple of minutes.I might be pickin' your brain a little with this program,hope ya don't mind...
Texas Jim
Ft. Worth
Not a problem... anytime... :)
dirtyoldman
Saugus,Ca.
Hey Gary!
Sup Jim,yeah,even tho it's an old system it still is impressive.After reading the manual I was pleasantly surprised.I can only imagine what Justin has to deal with in the EFILive program :eek:
Jeff Dodson
