Operation Dump truck!
dietz4ibanez
Willow Spring, NC
Here are some photos and a video... Just a teaser until I can get some better pictures and video!
Here is the dump truck to be....
Used the dump bed off of this truck!
And here it is completed!
http://s166.photobucket.com/albums/u103/dietz4ibanez/?action=view&current=0616092027.flv
Nice work, Brian! Did you do it yourself or have it done?
dietz4ibanez
Willow Spring, NC
I failed at getting pictures cause we did this the weekend before last and we were in a hurry...
But I will give you the run down...
Saturday we cut out the scissor lift on the old truck disconnected the hoses and cut the frame before the hinges...
Lifted the rear end of the dump bed with the bobcat and places it on stands... Uses a come along to keep the still attached scissor lift up against the underneath of the dump bed... Used air jacks to lift from of dump bed...
We had to take off the outer tires of the old truck to get it out from under the bed... And visa verso to get the diesel under the bed...
Sunday
We ended up just setting the dump bed on the frame... We had to add about 7 3/4" to attach the hinges to the chassis of the new dump truck. Lifted up dump bed to full extension while welding and bolting scissor lift in place...
We bolted and welding electric pump to the outside of the frame added Drydrolic fluid... Ran wires to the battery and the wired remote into the cab...(We have like 20' so we can step out of the truck to control the bed)...
We then cut 2 ft off of the back of the bed and cut and rewelded the backing plate to the bed w/ new led lights!
The LED lights had no reverse lights so I added small spot lights that come on when in reverse! I am going to install a toggle switch so that I can turn them on manually!
For not its good! I will try to get pictures of said work!
Sunday
Drkining adn tpyig dust jon't mixx, mmkay? :D
V
Vmax2007
Sunday
What do you mean? That's the best I have ever seen from brain. :dunno:
Nice job Brian....keep it up. :thumbs:
77eltigre
