Oil in spark plug tubes
Discussion in 'Mechanic's Corner' started by slims, Dec 24, 2016.
  1. slims
    slims If you cant have the truck you love, love the truc
    gonzales LA.
    I got a 2008 mazda 6 with the 2.3 4cyl. It's only running on 2 or 3 cylinders. Went to pull the plugs and there is oil in #2 and #3. Is this a simple gasket fix?
    [​IMG]
    [​IMG]
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  2. Kennyray
    Kennyray No Whiners, Violaters will be bitched slapped.
    Ossian, IN
    I would install a new valve cover gasket and spark plug tube seals.
  3. slims
    gonzales LA.
    New plugs and gaskets and it runs better than before. I used a roll of paper towels to get the oil out.
  4. txab
    That oil is supposed to be there, keeps your plugs lubed really well. You need to check your blinker fluid level and muffler bearings at this time too. :jester:
  5. slims
    gonzales LA.
    It runs great now but every now and then it hiccups and loses a cylinder again. The coils got oil in them. I cleaned them real good but I may need to replace one.
