NNBS transfer case issues please help
Discussion in 'OPEN TRUCK DISCUSSION' started by fortplainman, Jan 3, 2016.
Car Parts
  1. fortplainman
    fortplainman Custom User Title
    upstate ny
    so long story short a little more than 2 years ago i had my transfer case go on me. every time i put any power in reverse it would seem to drop out of gear and have a nasty grinding noise. a snap ring broke on the shaft and essencially caused a shitload of shrapnel in it and i had it replaced with a gm remanufactured unit.
    so fast forward to the past couple weeks, had the same thing happen from what the tech told me. i dont care about fixing it, that isnt the issue. my issue is if anyone has heard anything like this problem in other nnbs trucks and if they had a lift/tires/tune/gears etc. i have looked around a couple forums and have found nothing. i just dont see what could cause a second transfer case to blow up on me or how/what can be done to strengthen so so called snapring from breaking.
  2. 1BADSS396
    1BADSS396 Chief Pot Stirrer
    Mesa, AZ
    What is a NNBS? :dunno:
  3. daddy
    daddy Administrator
    Assuming you mean the GMT900, I don't recall this being a common issue.
    Did the rebuild have a warranty?
  4. fortplainman
    upstate ny
    The rebuild only had a 18 month 100k warranty and it's 27 months old and 20k miles
    FFB device
  5. daddy
    daddy Administrator
    Have you spoken with them yet?
  6. fortplainman
    upstate ny
    Working on it
    FFB device
  7. Nick The Great
    It's the generation of trucks before the NNNBS. Duh :rolleyes:
  8. PenguinLTZ
    PNW
    Man, that is crazy. I have not heard of this issue.
    Let us know what they say.
  9. fortplainman
    upstate ny
    found a service bulliten on gmt900 trucks made before april of 2008. snap ring on the rear output shaft was a different hardness rating that they changed and could break. causes grinding/howling/transfer case disengaging under load which my truck would do.
  10. Darkanion
    Hopefully that's all that's wrong with it! :thumbs:
