Need Help, Steering Wheel Buttons, 2007 Silverado
Damn, that's why I was afraid of.
I'm wondering if it has to do with this Viper alarm and shit. Might take it to the local Car Electronics place and see if they can't diagnose anything before I take t to the dealer.
It could be. They had to disable the stock auto start, I suppose.
I would ditch the Viper, and take it all back to stock
OneSlowRhino
Is it possible that only some stuff doesn't work and some does?
Thins that work.
I have manual windows.
Gauges.
DIC.
Radio (aftermarket).
Temperature controls.
Lights/light switches.
Horn works.
Things that don't work.
Steering wheel buttons.
-no lights
-no cruise or cruise light
-no radio functions
Traction control button
Pedal adjustments
Whatever the third button is.
-are these buttons still there if my truck was not equipped?
airbag light is on.
I no longer have the factory key fob, everything runs off the VIPER. Along with my "auto" door locks. Not sure if those were added.
I do have the build sheet. It's a work truck with a few factory add ons.
And all of it worked before?
Mayhap the installer borked the BCM, and it finally gave out.
Double check all the grounds you can find, as well.
OneSlowRhino
Not since I have owned it. I was told everything* worked. But I never tested every switch. Was worried about the essentials, didn't think the radio controls would work, but didn't think to try cruise until I was on my way home. I've only owned it for a week.
-this is just a reminder to myself why I like to buy my vehicles stock and do it myself, didn't realize with 24k miles I'd run into a cluster f*** like this.
OneSlowRhino
Just an update.
Removed the Air Bag and everything looks good. All fuses look good. It's going into the electronic place to look it over and potentially just remove all the remote start/Viper system.
Not what I wanted but I need to narrow down my issues.
OneSlowRhino
Removed everything beside the aftermarket radio.
They checked to make sure the radio was hooked up correct.
And back to square 1....
It didn't help anything. The same things don't work. Fak.
You are going to have to take it to the dealer, it has to be the BCM profile
I agree, these new vehicle rely so much on the BCM to make everything work. It wouldn't take much to cause issue. You might want to call the dealer up and just ask how much to have your BCM reflashed. It wouldn't hurt anything and can only help.
You covered all the bases with making sure the connections are good and all the fuses as well. Never hurts to check all the grounds. Amazing what a bad ground can cause.
sdsurf73
