Misfire #6 cylinder
Discussion in 'OPEN TRUCK DISCUSSION' started by gsta86, Aug 31, 2011.
Car Parts
  1. gsta86
    gsta86 I'm too LAZY to Choose a Custom Title!!!
    Mililani, Hawaii
    wich cylinder is #6? looking at the engine? alos, bank 2 is lean, should be the same bank as cylinder #6.....leading me to believe that i got a bad fuel injector. gimmie your 2 pennies
  2. Kennyray
    Kennyray No Whiners, Violaters will be bitched slapped.
    Ossian, IN
    What you working on ? And what size engine ?
  3. Zembonez
    Yessir. We need some clues sir.
  4. Bigredmariner
    Josh, passenger side is even numbers (2,4,6,8) and also bank #2. So if you fix your misfire you will most likely fix your lean condition.
  5. skeet
    skeet EvlRed 10 Sec Club
    Port Arthur Texas
    did ya fix your problem? you can try swapping coil packs on that side to see if it moves the misfire.
  6. OldCracker29
    :withstupid:
