Low Idle Problem
Discussion in 'Technical Questions?' started by junior3815, Dec 24, 2011.
  1. junior3815
    junior3815 Get 'em, Got 'em, Good
    Fuquay-Varina, NC
    My truck when I start it at a cold start starts and maintains 800rpm. Most trucks will revv and idle at like 1200 rpm for thirty seconds. also when going up a hill if i dont give it enough gas it acts like it wants to knock off. Always had this problem, has a brand new fuel pump and fresh fuel filter. Any ideas:dunno:
  2. DV2000NJ
    DV2000NJ The Browmaster
    Central NJ
    Any codes?
  3. Cowboy Cadillac
    Cowboy Cadillac Ain't no trash in my trailer!
    Grande Prairie, AB, Canada
    Fuel pressure regulator or a dirty intake. I know I had a dirty intake around the butterfly holding it open slightly allowing too much air in causing a low idle/bog. Fuel pressure regulators are common replacement items on gmt 800s, so I've been told. Check to see if its wet inside hose to regulator( its on DRv side fuel rail IIRC.)
  4. junior3815
    Fuquay-Varina, NC
    No codes being thrown, ill have to check the regulator
  5. OldCracker29
    This is where I'd start.
  6. skeet
    skeet EvlRed 10 Sec Club
    Port Arthur Texas
    this a completely stock truck? if so like mentioned id check for leaks around the intake, lean throttle body, clean MAF
  7. ScottyBoy
    ScottyBoy No, that's not a banana in my pants.
    My truck has idled at about 800 or so RPM's since I bought it in 2006. However, it will increase slightly if the AC is on. :dunno:
  8. OldCracker29
    :lurk: Did you get it figured out yet?
  9. junior3815
    Fuquay-Varina, NC
    Not yet work has been so consuming lately
