IH 54 R-100 4X4
Jesse S
Belleview Florida US of A
Round 2 turned out looking pretty good ...
Could let it harden up, sand it with 600 grit and shoot a coat of satin clear over the top ... Or leave it as it is ??
Jesse S
Doesn't look bad as is.
Ya talked me out of it ...
I'm going to leave it alone ...
The whole idea here is to keep the glare down ..
With having a custom tinted windshield with a sunband made into the glass ..
Pretty much covered that goal ..
Seeing a stoplight with running a outside visor might be a tad hard to do.
Aftermarket has a cure for that problem ...
Didn't like the idea of drilling a hole in the dash to mount the thingie, used a hole that the factory drilled for electric wipers ..
Took a little work to make that happen ...
Seeing a stoplight with running a outside virso might be a tad hard to do.
That's pretty cool. :thumbs:
Jesse S
Well, it's beginning to look like I got a thing for big blocks .. !!
Another 4-bolt 454" Mark IV followed me home ...
Got 4 of them in the shop at the moment which is 3 too many !!
Not wanting to do the tear down/clean up on this one due to me being a lazy bastard, think I'll put it up for sale 'As Is' $400 ...
Edit; Sold ..
Here's photos of the other 3 ...
This one is NOT "For Sale", it's bored & stroked to 500 cid and soon to be installed in my 54 R-100 .. Got a few bucks in this critter, I'm here to tell ya .. !
This one is a Std. bore 84 4-bolt, did a bit of work to it cause I was going to sit on it as a backup for the 500 ci motor ... But decided to sell it too ..
Here is number 3 ...
It's a 2-bolt main that has never been apart (Low Miles) but for the heads, I swapped out the peanut port heads to Gen VI heads .. That move bumped the compression up nearly a full point and netted better flowing heads ..
It's also for sale ..
Sweet! I can't wait to see the top one sitting in the 54 R-100. :thumbs:
Jesse S
I'm further along with the project than I was .. :cheers:
Next month will primer the passenger side of the cowling, working towards getting color on the firewall & windshield frame ...
After the color is laid on things will start to go together fairly quickly ..
Windshield gets installed, M/C mounted, firewall pad goes on and steering column installed, mega under dash work ...
Wiring the fuse panel is also on my plate to do ..
Still have the engine to finish going together ..
WillieT
