How to: Carbed SBC in a GMT800
04SilveradoMykk
Prescott Az
Hey Guys,
I know this isn't a tech write up that will be used in day to day life, but more to answer that question 'How?' and resolve any general curiosity.
How to Install a Carbed Small Block Chevy in a GMT800, focusing on a 4.3L to SBC swap.
The SBC is a piece I built in a machine shop:
86-95 four bolt roller cam block, bored .040" over
906 Vortec heads, modified
LT4 Hotcam
1.6 ratio roller rockers
.525"/.525" 218/224 dur @ .050"
Comp 26918 beehive springs & hardened pushrods
Balanced ZZ4 rotating assembly
H345NCP-40 pistons
10-1 compression
Old 4.3L engine removed:
Transfer the 4.3L accessory brackets & pulleys over to the SBC v8, with some modification to clearance the tall valve covers.
As you can see, the SBC was originally fuel injected using 96+ L31 injection with the upgraded fuel injection spider. The K&N intake, 75mm throttlebody and several other little performance add ons were all transfered over from the 4.3L V6
Grafting over the fuel injection plug in
Re-pinning the PCM to the V8 firing ordered and adding wiring for two more injectors
Adding the custom made 3200rpm stall converter. Since I'm using a '04 4L60E with a early model engine block. There were several changes made between the two, one being the bell housing on the trans, it's more shallow on the late model than what had been used on the early stuff. Instead of adapter plates, I opted to have that slack taken out with a stall converter.
OE converter on left, my swap converter on the right
Adapting motor mounts, I decided to use a LSx to SBC adapter plate intended to drop in a LS1 into and older muscle car body. I used the same plate, but it's theory in reverse.
Since my truck is a v6 to v8 swap, not only did I need the 4.8/5.3 motor mounts, I also need the motor mount to frame brackets from a V8 as well.
Droping in the V8:
So there she is; a L31 fed, high compression, big cam, high stall, small block chevy in my 2004 Silverado. At this point in the swap I'm thinking " What have I done..."
I took the truck down to my shop to make the new exhaust for it, as well as spend time to write the new computer tune.
I spent weeks playing with computers and tunes, the trucks original PCM just couldn't physically be adapted to this generation of V8. Instead I used a 0411 PCM from an 02 express van, that PCM could control the drivetrain fine but it couldn't communicate with the rest of the GMT800 platform, my gauges were screwy, I lost A/C controls, I lost the oil pressure gauge, I even had to re-wire the ignition circuit... but it was running and I could drive it.
So I drove the truck daily to get to work & back, around town, etc.
I drove it for three months, the fuel injection just couldn't keep up with the demands of the motor. It had split BLM's, the PCM wasn't responding to O2's, and once that issue was fixed the PCM was commanding 100% injector PWM by 4000rpm. It had lack of power and was drinking 10- MPG
Instead of throwing more $$$ into a different kind of fuel injection, marine intake or otherwise, I decided to make yet another bold move. Install a Carburetor. An ol' tested & true, inaccurate, out dated and primal means of fuel delivery. But as inefficient as the ol' carb is, it sure can deliver big power easily... at the cost of fuel consumption.
04SilveradoMykk
Prescott Az
Going Carbed:
To get the fuel system of the 04 to cooperate with the demands of a carb, a few things needed to get changed. As you know, fuel pressure on modern FI runs in to 58-63PSI range. The carb can only handle a max of 9PSi before running into real needle & seat issues.
New pump: Cater 72GPM @ 5.75psi
But wait, if I no longer have fuel injection to worry about... hell I'm going to run better heads, bigger cam and more compression!
Patriot 'Vortec' heads, 2.02" /1.6" valves
Comp XR276HR-10 cam, same 1.6 rockers & comp 26918 springs
.535"/.544" 224/230 dur @ .050"
10.7-1 compression
The trucks PCM needs to see four signals from the engine to function the gauges & trans. crank position sensor, throttle position sensor, coolant temp and oil pressure.
So that means a TPS needs to get adapted to the carb
Adjustable FPR:
And there she is, this is how a carbed SBC ended up in my GMT 800.
So why not of done a 5.3/6.0 swap and be done with it?
At the time I did this swap, I worked in a machine shop. The block & heads just fell into my lap and I had the means to built this motor myself.
Building a performance LSx is expensive, especially without a core, brackets or accessories to start from.
Total cost involved up to this point, including fuel injection and than carb parts: $3750.14
Cheers ~Mykk
That's one heck of project. There's a lot of little things that can eat up a ton of time on a swap like that. Looks like a lot of fun though. Thanks for the awesome write up and pics.:thumbs:
AWESOME WRITE-UP!
Thanks for taking the time. It looks like you did a top notch install. I love it when people do stuff right. Very cooL!
:zembonez:
I've owned a 4.3 Silverado. I'd be willing to bet it felt like you added 1000 horsepower!
Stumpuller6.5
Shits gonna get Abrasive...
Canukian Land
that was a very good job man, some good "engine-uity". I`m contemplating myself building another 454 and using a marinized intercooler and larger supercharger....still a dream at this moment... but I`m liking it more and more.
again good job! :thumbs:
77eltigre
