GMT 900 Torque Specs
These specs are for 2008 4WD but many of the specs carry over to other years. If nothing else, you'll get a good idea how tight that bolt or nut should be. :D
2008 Chevrolet Silverado - 4WD | Sierra, Silverado (VIN C/K) Service Manual | Suspension | Front Suspension | Specifications
Fastener Tightening Specifications
Application
Specification
Metric
English
Brake Hose Bracket Bolt
9 N·m
80 lb in
Brake Hose Clip Bolts
12 N·m
106 lb in
Hub and Bearing Assembly to Steering Knuckle Bolts
180 N·m
133 lb ft
Lower Ball Joint Stud Nut
125 N·m
92 lb ft
Lower Control Arm to Frame Nuts
175 N·m
129 lb ft
Shock Absorber Module to Frame Nuts
50 N·m
37 lb ft
Shock Absorber Module to Lower Control Arm Bolt - 1500 Series
50 N·m
37 lb ft
Shock Absorber Electrical Connector
20 N·m
15 lb ft
Shock Absorber Nut - 1500 Series
890 N·m
59 lb ft
Shock Absorber Nut - 2500 Series
24 N·m
17 lb ft
Shock Absorber to Lower Control Arm Bolts - 2500 Series
80 N·m
59 lb ft
Spring Jounce Bumper Nut - 2500 Series
30 N·m
22 lb ft
Stabilizer Shaft Insulator Clamp Bolts
50 N·m
37 lb ft
Stabilizer Shaft Link Nuts - 1500 Series
23 N·m
17 lb ft
Stabilizer Shaft Link Nuts - 2500 Series
23 N·m
17 lb ft
Torsion Bar Crossmember to Frame Bushing Bolt
95 N·m
70 lb ft
Torsion Bar Support Link Bolt
95 N·m
70 lb ft
Upper Ball Joint Stud Nut
50 N·m
37 lb ft
Upper Control Arm to Frame Nuts
190 N·m
140 lb ft
Wheel Drive Shaft to Front Hub Nut
240 N·m
177 lb ft
Wheel Speed Sensor Mounting Bolt
18 N·m
13 lb ft
2008 Chevrolet Silverado - 4WD | Sierra, Silverado (VIN C/K) Service Manual | Suspension | Rear Suspension | Specifications
Application
Specification
Metric
English
Leaf Spring Mounting Nut
200 N·m
148 lb ft
Rear Leaf Spring Shackle Nut - 1500, 2500, 3500
95 N·m
70 lb ft
Rear Shock Absorber Upper Bolt - 1500, 2500, 3500
115 N·m
85 lb ft
Rear Shock Absorber Lower Bolt - 1500, 2500, 3500
115 N·m
85 lb ft
Rear Spring/Hanger Bolt
50 N·m
37 lb ft
Rear Spring Stop-3500
50 N·m
37 lb ft
Rear Stabilizer Shaft Insulator Nut - 3500
32 N·m
24 lb ft
Rear Stabilizer Shaft Link Bolt (Frame Side of Link) - 3500
95 N·m
70 lb ft
Rear Stabilizer Shaft Link Nut (Bar Side of Link) - 3500
53 N·m
39 lb ft
Rear Suspension Jounce Bumper
32 N·m
24 lb ft
U-bolts - 1500
100 N·m
74 lb ft
U-bolts - 2500/3500
160 N·m
118 lb ft
Application
Specification
Metric
English
Assist Step Body Mounting Bolts
90 N·m
66 lb ft
Assist Step Center Bracket Bolt
45 N·m
33 lb ft
Body Cable Body Side Bolt
100 N·m
73 lb ft
Body Cable Frame Side Bolt
85 N·m
62 lb ft
Body Mounting Bolt
60 N·m Plus 170 Degrees
44 lb ft Plus 170 Degrees
Crossmember - Front Engine Bolts LD
105 N·m
77 lb ft
Crossmember - Front Engine Bolts HD
70 N·m Plus 110 Degrees
52 lb ft Plus 110 Degrees
Engine Protection Shield to Frame Rail Bolts
20 N·m
15 lb ft
Engine Splash Shield Bolts
12 N·m
106 lb in
Frame Brace to Frame Bolts
50 N·m
37 lb ft
Oil Pan Skid Plate Bolts
28 N·m
21 lb ft
Steering Gear Shield (9D/0320A SHIELD-STRG LNKG)
20 N·m
15 lb ft
Tow Hook to Frame Rail Bolts
85 N·m
63 lb ft
Trailer Hitch to Frame Bolts
100 N·m
75 lb ft
Trailer Hitch to Frame Nuts
113 N·m
83 lb ft
Transfer Case Shield Bolts
20 N·m
15 lb ft
Transmission Mount to Support Bolts
40 N·m
30 lb ft
Transmission Support to Frame Bolts
95 N·m
70 lb ft
Pickup Box Bolt
85 N·m
63 lb ft
Thanks go out to MS3Dale from GM-Trucks.com for this information.
Thanks Jarrod.
grimey01
