GM to stop Duramax diesel output for 4 1/2 months
Darkanion
GM to stop Duramax diesel output for 4½ months
Dealers concerned about possible shortages
Richard Truett
Automotive News
September 30, 2009 - 12:01 am ET
UPDATED: 9/29/09 8:37 p.m. ET
DETROIT -- A 4½-month pause in production of the Duramax diesel engine threatens supplies of profitable Chevrolet Silverado and GMC Sierra diesel pickups.
Not only is GM's pickup inventory lean, but analysts also predict that sales will start to recover while the Duramax engine plant is down.
GM is scheduled to stop building the current version of the Duramax in mid-December. Production of a re-engineered 2010 Duramax is scheduled to restart in late April.
During the pause, GM will retool the Moraine, Ohio, plant where the engine is built, and GM engineers will tune the 6.6-liter turbocharged diesel V-8 to meet tough new emissions rules that take effect Jan. 1.
The revised engine will add a system to inject urea into the exhaust periodically. The chemical reduces oxides of nitrogen or NOx. The pickups will add low-fluid alerts to prompt drivers to refill the urea tank.
Some dealers worry they may run out of diesel-powered versions of the Chevrolet Silverado and GMC Sierra because of the gap in production.
“We got a notice yesterday that starting immediately, we can no longer order the Duramax regular cab,” said Scott Brasher, general manager of Brasher Motor Co. in Weimar, Texas, near Houston.
Brasher still can order extended-cab diesels, and he expects to place his last order for them next month. He also has been buying diesel trucks from other dealers to pad his inventory.
GM Powertrain spokesman Tom Read said GM plans to build inventory of Duramax engines this fall. The Duramax for the 2009 model year can't be built after Dec. 31, but engines that already have been built can be installed in vehicles after that time.
Ford Motor Co. is also launching a new diesel truck engine next year. But spokesman Anne Marie Gattari said Ford dealers will not run out of diesel-powered Super Duty trucks.
Gattari said Ford will stop production of the 2010 model year F-series Super Duty in February and then switch to a new engine and revamped truck in the first quarter. Ford's re-engineered diesel pickup also uses urea injection to reduce harmful emissions.
As of Sept. 1, GM had a 60-day supply of Silverados and a 71-day supply of Sierras. GM won't say how many of those are diesel-powered.
“We've been communicating with dealers, and we feel very comfortable we can meet their needs,” said GMC spokeswoman Dayna Hart.
Chevrolet spokesman Brian Goebel said GM will build up diesel pickup inventory for the rest of the year. The company also uses the Duramax in chassis-cab models and large vans.
Brasher said many more buyers are taking a second look at the gasoline-powered version of the heavy-duty Silverado because of the high cost of the diesel engine and the higher cost of diesel fuel.
“We're having much better luck with the gasoline engine,” he said. “Right now sales are running 60 percent diesel, 40 percent gas. But three years ago, it was 90 percent diesel and 10 percent gas.”
GM is spending $70 million on the Duramax plant.
They'll recover fine after the re-tooling.:thumbs:
I don't doubt that in the least.. I just wasn't aware of them shutting down for that long. So, I thought I'd pass along the info. :cheers:
Good info, I thought I saw somewhere that most retools where around 60 to 90 days so yeah it is a little longer. looks like everybody is going to the Urea injection now with the new regs.
svensk
TMC's official Zombie Slayer
You betcha
screw having a diesel now. I don't want to have to deal with that crap.
RebelThunder
Speak English or GTFO
A Tree Stand
This is the first I've heard of this urea BS. If I ever needed to buy a diesel it'd be pre-LMM for sure.
mr_bots
Fort Kickass
I'm not sure why this is news, I've seen it a few places. It's not uncommon to shut engine factories down so they can be retooled. As for the urea injection...just more cost to the already expensive diesel. They should make a kit where you can just piss into the truck for the urea. Why buy it when you can just make it a rest stop that goes along with you?
grimey01
