bubbatrucklover
Heavy Metal Red Neck
That's a nice CB![]()
Most reviews I've read on functionality, looks and features seem to make it almost the Cadillac of CBs
So I'm kicking around getting a CB for the truck "just because". I'm most likely going with this:
http://www.walcottcb.com/cobra-29-lx-multicolor-faceplate-radio-p-2074.html.
I will be mounting it in place of the factory aux tape deck after modifying the opening. Giving it a "factory installed" look.
Rather then running a splitter and one antenna I was thinking of a pair of these:
http://www.firestik.com/CatalogFrame.htm
One mounted where the factory radio antenna is and the other symmetrically opposite with a set of these (probably the Model K-154A) :
and running grounding straps to the frame.
Is anyone running this set up the same way? Would Ya'll go with a pair of 36"s or would 24"s be sufficent?Are theses antennas flexible enough they can with stand getting smacked around by a car wash, branches etc. mounting them on the cowl?
Thanks in advance for Ya'lls input.![]()
Firesticks are good antennas...
Use the longest one you can get and still be practical.
The firestick "SCREWS" into the mount.
Carry a little open end or a small Cresent wrench in your console.
When going to the carwash... it takes about 10 seconds to unscrew them and lay them in the floorboard.
About 12 seconds to put them back on...
That way nothing gets broke and you don't get gray hairs worrying about them...![]()
When it comes to communications Bernie DEFINITELY knows his shit.![]()
Between those two choices, the 3' (36") would be the better choice. Remember, longer is better with antennas. (I won't go into the different ways of "loading" an antenna, but I will say that a spiral wound top load is the most efficient in comparison to center load and base load) Ignore the power ratings. A) unless you run an illegal amplifier they won't matter and B) if you do run an illegal amp you probably won't be satisfied with those antennas anyway.Fwonk me BernieLet me quote myself:
Thank you SOOOOOO much for that VERY descriptive detailed explanation.
I heard the term "ground plane", but was unclear as to the specific definition.
and the NOAA frequency compatibility didn't even occur to me. I would have been pissed and confused had I got an antenna that didn't receive those frequencies properly.
To tap your knowledge a little further, the 2 Firestiks (for example) one (the 2 Ft 5/8 wave) is rated @ 100 watts) and the other (3 Ft 5/8 wave) is Rated @ 300 watts.
What exactly is the 100 and 300 watts referring to.
Thanks again Bernie.Based on your advice I now have to decide if I want to have an antenna on my roof or back fender.
If not I can expect less then optimal signal or just not go with a CB all together.
You need to be careful how you run the coax because sharp bends, hard edges and frequent bending can all damage it internally, and your first clue anything is wrong will be a CB that receives okay, but doesn't transmit worth a lick... and a hefty repair bill to fix it.Don't give up on a CB,they're very usefull when traveling in a group,especially when off-roading.
I bought a cheapy Cobra last year and mounted it where the tape deck was..I already had a magnetic antenna so I mounted it on the roof above the rear doors and ran the wire down the rear door jamb under the rubber door seal,then under the driver's seat and up under the dash.I don't really know the range of the signal but when in a close group it doesn't really matter.
No cutting or drilling![]()
If I am not mistaken... and Bernie can correct me if I am... the wave length for a CB is 102 inches...which equals 8.5 feet.
If your dual antennas are an EXACT portion of the length apart, they will not interfere with each other.
That is one reason you see so many double antennas on the mirrors of BIG trucks.
Another for instance.... if you had 2 of the 5/8 wave antennas and mounted them 63.76 inches... they are now EXACTLY a 5/8th wave apart from each other.
The wattage that is referred to is the max output the antenna can handle if you wanted to put an illegal booster on the CB radio... they are called linears...
