geektoad
redneck geek
....is going no where.
plastic shield is off.
jack under it holding it
straps are off
I can't reach or see anything on the back side of the tank where i'm supposed to disconnect the filler tube, return line and the wires.
I assumed I could drop it down on the jack a little to get access and see wha the hell is going on, but when I lower it, the front end drops but the rear doesn't budge. I don't want to drop it very far cause I don't want to break anything. There's probably 6-7 gallons in the tank, so not a lot of weight, but enough to bend something I can't see.
The install instructions from FASS are a fucking joke. No detail about anything and some stuff is just flat wrong (which fuse to put the add-a-fuse into).
The problem I'm having is this install (2015-2016) is different than the previous LML install, so there's not much info out there from anyone other than FASS's instructions.
one other thing i'm starting to worry about is whether the gooseneck hitch has something back there pinned, though it all looked clear when I was installing it.
I assumed this was going to be a simple install, and I really wanted this installed to pull the new camper, but at this point I might button everything back up in the morning and go after this when we get home from our trip.
grrrr.
straps are off
grrrr.
