crmzendrgone
I may be fat but your ugly and I can loose weight
Been away far to long!
So I failed emission, high HC and CO, things done to engine prior to test: new plugs, wires, cap and rotor. Found when replacing all that, there was oil soaked plugs. More info, runs rough and sometimes misfires, misfires most when WOT.
So, the question anything easy to look for to get it to pass? I was looking on the old inner web and some suggest cat, I'll except that answer seeing as how last one installed was around 2009-10ish. It has 220k miles. Could be time for an overhaul. Any comments suggestions; good, bad, funny are all welcomed.
I'm ruling out EGR, new one just one year old. Umm, just had to put a new fuel pump in few months ago. Ah, maybe intake gasket, that could be leaking.
My concern is the oil soaked plug, valve seals?
Again, thanks
Again, thanks
